ArizonaMatt
Member
Hi all. I've got an Adcom GFA 555 (series I) and I'd like to use my Carver Receiver 900 as a pre-amp. The receiver does have the "pre-out/main-in" connections. Some questions:scratch2::
1. Am I right in assuming that having the pre-out/main in connections on the receiver means that I can use it as a pre-amp?
2. What are the connections that I'll need to make to do this (I'm embarrased to have to ask, but can you literally tell me exactly what plugs into what)?
3. When doing this, should the "bridging switch" on my Adcom be switched on?
4. Is what I'm proposing actually "bridging?" I don't think so...but what do you call what I'm talking about here and how does it differ from bridging?
5. Assuming what I'm proposing is not in fact "bridging," would it be possible (and is there any rationale) to bridge my Adcom and the Carver receiver? What about bridging to a Carver Receiver 2000 (that way both amps would be contributing 200 watts--is matching the power between two bridged amps important?).
Any info would be much appreciated!
--Matt
--Matt
