Montmorency
I read in often encounter in various sources (both turntable-related and cassette deck-related) mentions of different speed control systems, including the oft compared "FG servo" systems and "quartz-locked" systems. Quartz-locked systems (or "quartz PLL systems") are presented as more modern and superior to "FG servo" systems.
I know very well what quartz PLL speed control system is: a stable quartz-based oscillator generates a reference waveform, while a FG coil in the motor provides a speed-dependent feedback waveform from the actual motor. A comparator performs phase comparison of the two waveforms, extracts the phase difference and turns it into the speed control signal, adjusting the speed of the motor. This negative feedback system strives to keep the two waveforms in-phase.
But what is "FG servo" system then? How does "FG servo" system work? How is it different from "quartz PLL" system?
I found this thread in this very forum: https://audiokarma.org/forums/index.php?threads/what-does-fg-servo-system-mean.403440 But the people who answer there don't seem to care much about the difference between "FG servo" and "quartz PLL". They attempt to answer the question about "FG servo" system, but instead drift into the description of "quartz PLL" system, as if the two are actually the same.
So, would someone please illuminate me on this very specific and focused matter: what is the distinguishing feature of "FG servo" speed control that makes it different from "quartz PLL"?
I presume there's no quartz in "FG servo", right? But apparently there's an FG coil and some sort of feedback from it. Is there? And if so, where does that feedback go and how is it used then?
