Hello and Good Day/Afternoon/Evening to everyone
so my father has this Aiwa SA-P50H that he bought a few years ago and its all original but has an issue, sound comes out distorted (mostly on one channel, the other one its almost indistinguishable but its there) going by memory
so the amp behaves as follows:
Amp turns on and relay connects speakers successfully, however the led scale on the front lights up to the 3rd led (0.5W mark) with no audio input
i took some measurements with the help of the Service Manual
(i never turned on the amp more than 30 seconds at a time, enough to measure voltages and shut it down immediately)
DC Voltage at speaker terminals
Right Channel= around 6.0mv and goes down slowly
Left Channel= around 0.4v and doesnt seem to go down much if at all
Zero Potential (DC Balance) (supposed to me 0mv +-3mv)
Right Channel= 5.6mv and seems to go down slowly
Left Channel= about 0.4v about the same as speaker terminals
Idle Current Adjustment (Bias) (supposed to be 8mv)
Right Channel= 0.014mv-0.007mv
Left Channel= 54.4mv (yikes)
so since i dont have much experience yet i was hoping for help in what to check, i assume at the very least check everything on the left channel driver board, but id like to avoid de-soldering and taking things out more than absolutely necessary
(i have attached the amp schematic as a PDF because the image is being compressed)
As always any help is greatly appreciated
