Brian Beck
The Fultons' have some kind of fuzzy coating or debris on them.
I think that's called dust
...BobF seems to've been fastidious, to the point of specifying differences in the precise offset distance for stacking the 2 mid module choices.
Yes, he was. Actually it depends on where you sit relative to the speakers and how high your chair is, etc. I spent hours sliding the electrostatic tweeters forward and backward relative to the mids. I used a well-recorded female voice and could tell when the phase fronts were "locked in". Trust your ears on this.
The Mid module 6" seems to have a permiable dust cover. hmmm! I'd thought it was Acoustic Suspension! What do I call this cab?
Actually it is an 8 inch driver, but anyway...Most sealed cabinet boxes really aren't perfectly sealed - all have some air leaks. At very, very low frequencies all 2nd order sealed boxes really behave as 4th order vented cabinets. The goal is to make the air leaks small enough that the speaker rolls-out initially as a 2nd order sealed system, and that the additional two poles of a vented system don't hit until well below the working band. I suspect air leaks through the dust caps of the Rola woofer work like that - not a big enough "port" to hurt things in the intended pass-band of the driver. The benefit, besides voice coil cooling, is to avoid the resonance of the trapped air between the pole piece and the dust cap. Dick Sequerra removed his dust caps altogether, even in his sealed boxes.
