Hi, (also posted on th forum)
I need opinion of you experts. I have an Akai 4000ds that I have cleaned pots, switches, heads etc. and it seems to work very well except for a static-like noise that is random, mostly on left channel. See the video below. It only does it when monitor is set to tape. I think it is also getting worse. Is this a case of the bad 2SC458 transistors? If so, how many will I need and will any KSC1845 do? I'm fairly experienced with electronics but wanted to check if anyone has had the same problem.
Thanks very much.
Thanks very much.
