mallardice
Ok, I checked all the resistors on the right channel board and they all look fine, and I did the transistors on both boards (I'll try and do the other resistors later). TR1 (2SC900) and TR3 (2SC959) on both boards seem to have failed, so I suppose I should desolder them and check them out of circuit. Could these explain the high DC and fuse failure? I'll also try and remove the output transistors that tested fine before to make sure they're ok out of circuit too
