Hello, Any Akai Tape heads out there? Have an Akai CS-703D cassette deck with nonfunctional Auto Stop.
Worked sporadically when I first got it and I assumed it was worn/loose belts. All were replaced with new
and all appears to function fine except for the Auto Stop. I could live with this, if it was play mode only,
but it does so with tape FF and REV modes, and makes an ugly grinding sound when doing so.
I suspect, when I was disassembling for the belts install, I made something worse and/or there is reduced
tension somewhere. Possibly it is the small tension spring, underneath the bracket holding the cam assembly
which provides the mechanical stop function. It may be too loose or installed incorrectly. Some of the archive
threads discuss this very issue but there was no response or it was inconclusive.
Any thoughts/guidance/photos would be much appreciated. Thanks
