Akai gx 620 capstan motor fails
Gangmania
Hello,
Recently i got this akai gx 620 and when i push the play button, it runs for a little while (20seconds) and then slowly stops.. After that it sometimes finds some courage and spins again for a little bit but also fails after +/- 20seconds.
What could be the problem, i learned myself that the TR13 is a common problem with the capstan motor, but its mostly not running or running too slow/fast and that is not the case with me. Mine just loads some energy, gives it back for a while and starts that cycle again,...
Thanks you in advance
