Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Can someone please tell me which transistors need replaced on the AKAI GX-635D's and where they are located ?? Pics are always appreciated Thanks so very much !!! Dan
Here are the ones I replaced - and fixed my low/no output.
Replaced TR3,4,7,8,9,10 - including the 'B' of each. Wasn't as difficult as I thought it would be, except TR 7B and 8B located under a switch. De-soldered and removed the old ones and mounted the new ones on the 'solder side' of the board. Just need to make sure you get the polarity right.
I believe there are 14 in that deck. going from memory tho so take that for what its worth. Last GX-4000D I did had 14, GX-630DB had 18 due to the Dolby pcbs. Double check...:yes:
Just picked up another 635D last weekend. If I EVER get the mildew smell out of it,
:tears:
I'll bring it in and go thru the machine. I'll let you know.
Tim
