Halisson
Member
Hello guys.
I'm doing maintenance on a AKAI GX630DB that was an initial problem of not trigger the FWD. Located TR6 damaged transistor and diode D17 in TE2002 - Relay P.C. Board, after replace components and the FWD is OK.
After checking the FWD to be working, does not sound playback or sound recording, but in monitor mode / Source REC, the input signal is recognized by the VUs TAPE not record or reproduce any signal.
quickly view RELAY PC BOARD TE2002 and P.C. CYSCON BOARD TE2001 have damaged components.
I was not sure if the function could be the MUTE the P.C. CYSCON BOARD TE2001 board to pin 1 and 2, but without these pins does not change anything.
Sorry my bad English.
I appreciate any help.
