I’m glad you sorted it all out.
Other than that bit of frustration, are you enjoying the build so far?
I put some cheese on to smoke and made some more progress with the build today.
... populating boards and soldering things or repairing things is my destresser/therapy. ...
Thanks for your posting. I have the Akitika PR-101 preamp with phono stage on the way. Should start on it this weekend. I ordered it to replace my acurus LS-11 which is beginning to fail in the right channel.
What shop tools do you recommend? Solder gun is obvious, but what else is essential? Looks like you had some kind of circuit board holder? Mounted magnifying glass? Anything else? Thanks for the great tutorial and review.Here’s my official review:
I like it, it’s good.
That is all.
On a more subjective note, it’s currently doing shop duty and replacing an Onkyo M-501.
Comparing the two, the GT is far more... musical. I found the M-501 to be too cold, dry, sterile- while the GT-102 is far more warm and inviting. Not warm in a tube sense, but rather that its dynamics seem more dynamic.
It’s tones seem more tonier.
My god, I’m bad at this reviewing thing.
Mids sound clearer, highs are good, bass is tight. I don’t feel like I need more power, which is a feeling that a number of other amps have left me with.
Most importantly for me- no listening fatigue. That is something that I previously thought was speaker dependent, I wasn’t aware that an amp could affect it as well.
So there ya go. A super enjoyable, easy build of a very decent and capable amp that I highly recommend to anyone who likes to solder.
Bare essentials:
A good temperature controlled soldering iron (personally, I wouldn’t go near a circuit board with a soldering gun- tips are too large and it’s too easy to damage a board).
Flux & Rosin (flux for the board, rosin for wires).
Solder (I’m a big fan of 60/40).
Rubbing Alcohol to clean flux off boards after soldering (at least 91%)
A solder sucker or other way to desolder (braid, etc.)
Flush cutter (to clip component leads)
Various small hand tools- screw drivers, pliers, sharp utility knife or xacto.
Digital multimeter.
Things that are nice to have:
A proper soldering station with a variety of tips for the iron and with a desoldering gun.
A circuit board holder. If you search for “circuit board holder” on Amazon you’ll find a number of options.
Helping hands- those things with alligator clips on movable arms with an attached magnifying glass. Do a search for “helping hands” on Amazon and you’ll find a number of options. Make sure you cover that magnifying glass when it’s not in use if there’s any chance that sunlight could hit it, unintentional fires are bad.
Wire Stripper
Various sizes of sharing tubing.
If you’re soldering skills aren’t up to snuff, practice on something unwanted/unneeded (dead electronics, thrift store stuff, etc.)
Happy building!
fantastic build. was the ground loop breaker part of the kit or did you add it yourself? I like how absolutely beefy it is, its probably the biggest rectifier chip that you can get for consumer market
