Every time I post somewhere about cleaning records (the solution I use was recommended by the manufacturer of my RCM and is isopropyl alcohol, water, with a drop of dish soap) invariably someone responds with the claim "alcohol leaches plasticizers from vinyl". I find this claim dubious, but I'd like to see it addressed so as to reduce the FUD around cleaning vinyl records.
Firstly, I am not a chemist. I have taken one university level chemistry course and that is the level of my expertise. However, I still find this claim about leaching doubtful. Isopropyl (or any other commonly used alcohol) couldn't interact with the composition of PVC for the same reasons that oil and water don't mix.
Water and alcohol are polar molecules. They have a positive and negative end to them. The attraction between the positive and negative poles is what keeps water molecules together. The polar nature also allows them to dissolve (or pull-apart) other polar compounds. Alcohol dissolves in water and vice versa.
Plastics and oils are not polar. They are held together by what is called van der Waals forces. Basically polar molecules like alcohol and water can't disrupt the forces that hold oil or plastic together—which is why oil and water don't mix.
Obviously, this is a huge simplification, but it forms the theoretical basis for why you probably don't need to worry about using alcohol on vinyl records. I specify vinyl because alcohol will damage shellac 78s and also acetate DJ pressings. Those however are not vinyl. Also, I would be hesitant to use non-polar solvents on a vinyl record. I wouldn't try to clean a vinyl record with lighter fluid, turpentine, white/mineral spirits, WD-40, or anything used to dissolve oil. Perhaps some of these are safe to use on vinyl records, but coming from a theoretical standpoint it isn't a good idea.
I'm also not going to try any strong acids or bases—although Drano (sodium hydroxide) might not harm vinyl (I've done lab experiments with sodium hydroxide and it is very dangerous stuff).
Any chemists out there who can confirm on deny what I've said? I've never made any polymers, so I could be wrong. From chemistry standpoint it seems like there is little reason to think that isopropyl alcohol (or similar) will damage vinyl (just vinyl—don't use it on records that aren't vinyl) records.
