Alec 604-8G Crossovers
Awesome, thank you! I am going to go ahead and build one. Worst case I spend a little money and switch back to the old. Best case, I have improved a pair of speakers that were phenomenal to begin with. What did you use for the 30 ohm pot?
The "30 ohm pot" is just a standard L-pad, except that you are only using a portion of it as a variable resistor. It can actually be an 8 or 16 ohm L-pad. Use terminals #1 and #2. (And most are actually about 40 ohms.)
Piezo tweeters, distortion personified. A 604 with the right diaphragm is only down 4 or 5 db at 20,000 HZ. Just crank up up your treble control one or two clicks.
I was wondering about this. Can you explain with more depth how this works? I've seen 60 ohm L-pads specified in some crossovers and cannot understand the mechanics involved here. Can you enlighten the ignorant (me)?
GeeDeeEmm
Quite true. But, which would be the "right" diaphragm? Just curious.
GeeDeeEmm
attachment.php
