I will put another pic. My first was not a good one.
Place the disc on turntable (just like a record)
Rotate so the long ridge, A - B, is pointing to the pivot point of arm. ( I got a hint from this forum. Get a short piece of white cotton, fix one end, with a small speck of Blu Tack or something like that, exactly on the pivot point. Fix the other end to the B end of ridge. This allows you to sight from above the precise line of ridge.)
The with a small bit of tape secure the turntable from moving.
Now adjust cartridge so the stylus tip when gently lowered sits perfect on the dot in the marked grid on the right side.
When it does, look from above to adjust paralell in the marked grid.
This now is the part where patience is needed. In adjusting the paralell of cart it can move the stylus of the dot a fraction. Keep adjusting until everything lies up ie. the dot, the position in grid , stylus shaft with other grid E - D etc.
As previous poster suggested, do one screw first not to tight, until you are happy. Then hold cart firmly to tighten.
Anyway, this disc worked well for me, the other posters are more experienced than I.
