Not so sure... In fact, I disagree totally. Let us see for the Marantz 6200:
The datasheet for this table gives:
Effective length: 213mm
Overhang: 14mm
The offset angle is not specified.
If you experiment with different offset angle, using this alignment comparator
http://www.vinylengine.com/tonearm_...&m_oh=14&m_oa=22.5&compare=i&submit=calculate
you will find that an offset angle of 22.5 degrees will give only one null point but this is the alignment (if you stick to the 213mm/14mm) that gives the minimum value of the maximum distortion (1.14%).
It is possible that 22.5 degrees is indeed the offset angle of this arm, I don't know.
For any offset angle larger than 22.5 degrees, the maximum distortion will be higher than 1.14%. For example, for an offset angle of 23 degrees (consider that it is only 0.5 degree difference, you must have a good eye!) the distortion rises to 1.5%.
http://www.vinylengine.com/tonearm_...13&m_oh=14&m_oa=23&compare=i&submit=calculate
For an offset angle lower than 22.5 degrees, the distortion will be lower toward the end of the record but will be higher at the outer groove. For example, for an offset angle of 21.5 degrees you will have 1.5% distortion at the outer groove.
http://www.vinylengine.com/tonearm_...&m_oh=14&m_oa=21.5&compare=i&submit=calculate
My opinion is that you should follow the protractor Löfgren B or Baerwald and never, never follow the manufacturer alignment.
You should understand one important point. In most turntable the Pivot to Spindle distance is fixed by the construction. We can not change this value. We have some latitude with the Effective length and the Offset angle. But the ideal spot is not wide. Compare the Löfgren B and Baerwald alignments, they differ by only 0.5mm and 0.06 degree in this example.
Forget the aesthetic and go for the music. Don't hesitate to modify the headshell with a small file if you can't move the cartridge enough to satisfy the Löfgren B or Baerwald alignments.
