Chazix be better than me. Being a higher end tuner, it has more than the usual number of adjustments, though not by much. At least it uses ceramic filters, so there's no IF chain to adjust. I'm guessing it would take me half a day if all went smoothly. More likely, some anomaly occurs, something doesn't adjust the way it should or there's some noisy transistor, bad pot, out of spec resistor, bad solder joint or whatever. Suddenly a straightforward job ends up taking the entire day.
