Hi,In terms of getting the "tube sound," is there anything to be gained (is that a pun?) by having an all-tube (tube preamp + tube amp) system over a hybrid tube-solid state system (tube preamp + solid state amp)?
Thanks for your comments.
Seta do you have any experience servicing the Capitale? A friend has one and it has a slight hum in one channel. I have the service manual but haven't been able to figure anything out yet... Maybe best for pm or a new thread.Hi,
At present I have a McIntosh C26 attached to a nice Pilot EL84 stereo power amp. That system sounds amazing. It belongs to a friend and I just finished refurbishing both units. Another system I am working on has one of my rebuilt Dynaco PAS-2 preamps driving a McIntosh MC2205 amplifier and again, the system sounds quite nice. Then there is the all tube system consisting of a pair of my own design class A EL34 mono power amps and a HH Scott LC-21 preamp. All these systems sound a little different, but all sound really nice and none of the systems produce any ear fatigue. So, in my world, it is more about the quality of the components used and not whether it is tube or solid state. I have heard good and bad in both. In my years of servicing audio, my favorite solid state amps are McIntosh followed by Threshold. For tube the hands down best sounding amp has been the older Audio Aero Capitole power amp that uses a pair of EL34's in push pull parallel with a pair of 6550's in each channel. Second best has been the Jadis Defy-7.
HiSeta do you have any experience servicing the Capitale? A friend has one and it has a slight hum in one channel. I have the service manual but haven't been able to figure anything out yet... Maybe best for pm or a new thread.
Thanks! Wow, I just looked and you are right, the EL34's are in parallel with the KT88's! That is very odd, I hadn't realized that before, I can't quite get my brain around that. In this case he has 6L6's and 6550's. I wonder if the issue is in the interaction of those tubes, but I have switched all tubes around and it doesn't move or change. Thanks for the info.Hi
I have worked on a few. Most common problems are blown bridge rectifiers in the power supply and
bad or noisy 6SN7's The amp is like any tube amp in that any tube with excess gas can cause hum as
well as a soft and distorted sound. I would first try swapping tubes channel to channel and see if the hum follows a tube.
Failing that, I would check the power supply capacitors and all sections of the power supply. Although on one board, that power supply is not just a simple single bridge rectifier feeding everything. There are four bridge rectifiers, if memory serves, and they feed different sections of each channel. It is possible for one channel to have a bad power supply capacitor. The main ones are black and stick through the chassis. Also, this amp uses two EL34's in push pull parallel with a pair of 6550's. Since it is self biasing, you must use those tubes, with 6550's closest to the output transformers and the EL34's between those and the 6SN7's. Just curious where you got a service manual? I had never been able to find even a schematic for the Capitole or any other Audio Aero product. I believe Audio Aero used that same name on another product. A CD player, I believe. The unit I speak of is a big power amp using two 6SN7's as driver and phase splitter tubes, and a pair of EL34's in parallel with a pair of 6550's for output tubes. What kind of speakers does this person use? I ask because even when running correctly, the amp is not dead silent through speakers like Klipsch or other high efficient speakers. Make sure you use a shorting plug in each channel when testing for noise. Many times people blame the power amp when the problem is a faulty interconnect or other device upstream in the audio signal path.
