Alright fellas. I got as far as taking the dadgum thing apart. It is VERY dusty on the top inside. The bottom, not so bad. I fired it up first, and the FM Stereo Indicator bulb is out, as well as the bulb behind the signal meter (which looks pretty easy - screws in & out like a light bulb).
The volume knob is "tricky". It has 2 knobs stacked, I think one for balance and one for volume. I only ran the headphones for testing, and it was staticky, and definitely needs cleaning. Everything else seemed ok as far as the knobs & switches.
Nothing more dangerous than a NOOB w/a can of Deoxit and his first vintage piece so I need advice on any or all of the following questions. Please look at the pics, use the copy & paste if you wish and answer whatever you can. I'd really appreciate any help. (some are very basic)
1. What is "AFC"? (There's a switch for this on the front)
2. I think the meter lamp says Stanley 8V0.15At on the base? Can this be easily obtained and do you know where?
3. How about the FM Stereo Indicator lamp? UltraHogg has already indicated to be careful to replace it with the correct lamp. How do I go about determining the correct lamp? Unlike the meter lamp, this one is wired and "crimped" (I think) and I can't read anything on the base. Should I just skip this?
4. Can I use compressed air (like the cans for cleaning PCs) to SAFELY spray off all the dust and gunk on the inside?
5. Deoxit the miracle drug - I have limited experience with this. I LEARNED HERE that you are NOT to spray it on the FM tuner fins
so thanks to AK for that bit of knowledge. But I want to use it to clean the controls for bass, treble, volume and whatever else it is safe to use on. (also have the switches, tuning and selector knobs on the receiver) I can see by looking at the controls on the inside, a little slot on the side where I can see moving metal inside as I turn the knobs. Is this where I spray it?
6. The guy I bought the Deoxit from said to get a spare RCA cable and soak it up good w/Deoxit, insert it into the RCA jacks and turn back & forth. Is this the best method for cleaning? (Think I also heard "pipe cleaners" on here)
7. Piggybacking off 6, is it ok to spray Deoxit directly into the female RCA jacks?
8. Any other advice, ESPECIALLY precautionary for a noob working on his first piece of electronic equipment?
Btw, I'm not into all the soldering, replacing caps & stuff like that. If that needs doing I'll have to shop it out.
TIA for any and all help!! :yes:
PS - I took a pic of the lamps as well as best I could if anyone wants me to post that.
