Maddart
Just got an allied 498 from the trash pile. Plugged it in and the with the left channel fuse in and my light bulb equiped power strip glows.. Remove the left channel fuse and the receiver and right channel works ok, and the left channel sounds garbled without even a fuse.
Checked the outputs (2SD218) x4 and all are ok.
Appears that the amp board is almost identical to the pioneer sx-9000. I will check the transistors on the amp board next. This appears to be capactive coupled and both 2200uf caps look in tact.(No leaking)
This is all i can think of, if any one else has any ideas i'd appreciate it
Thanks
Mark
Thanks
Mark
An ohmmeter can tell the tale. Are those TO-66's, i.e. mini TO-3's? (I'm lazy)
