StuBotNYC
I am the proud new foster parent of a gently used and well loved pair of Allison CD9 3 way speakers in light oak.
Both have 10 woofers in need of refoaming, one has 3 splits the other intact and slightly tacky. I plan to do this on my own using
Simply Speakers of Florida's kit on ebay.
I have one broken dark brown grille on my HF section that was crushed and damaged the HF drivers.
I have one tweeter with both leads cleanly disconnected and a shorn off but attached dust cap.
I have one mid range driver with a soft dent in the center and an almost torn off wire.
The cabinets are mostly flawless with no signs of wear with a back corner ding and a small splinter sized area of removed veneer on the lower front edge.
The nickel plated steel is flawless with all foot pegs and screw found a user on etsy who makes reproduction grilles, anyone have them?
This is my quest.
Any help or advice in my duty as an adoptive parent of these beauties is greatly appreciated.
Thank you
Stuart
This is my quest.
Thank you
Stuart
