special_20
A friend's father was downsizing and I have been given a pair of Allison Acoustics Model 1 speakers. They were in somewhat rough shape: woofers foam was rotten, scrathes on tops, bases had seen some moisture damage. I am working on a moderate level of restoration to bring them back to life. So far I have:
I am now preparing to apply the finish and have some questions. I am was hoping to do a simple finish of a danish oil (I have neutral and walnut on hand) and maybe a wipe on poly for protection.
I believe the original finish was oak or walnut. I found some red oak edge band at the hardware store which I have applied and trimmed. The original veneer appears much darker than the new edge band veneer. When I wet the two, there is a pretty stark contrast in color. I'd like to get a closer match to the old veneer. How does one go about this?
Use a thinned wiping stain to impart a grey/red tone then apply danish oil?
Finish original parts with danish oil, then tint the danish oil finish for the new veneer in an attempt to color match?
other tips or tricks?
- re-foamed the 4 woofers
- stripped and sanded the original finish
- stabilized and leveled out the swollen particle board with some epoxy
- replaced water damaged edge banding on the bases with red oak
