alps blue velvet
maciek
I have built simple passive volume control for my hk citation ii using for my radio shack 100k stereo pot 3.50 $ or so,it worked surprisingly well and sounded great,last night changed it to alps blue velvet i bought from angela instruments,it sounds ok but is kinda muffled and lifeless,not as open and dynamic as rs pot,any opinions on that subject,alps suppose to sound better
The radio shak alps are fabulous, and they are cheap enough to buy plenty, then hand pick the good tracking ones.
They had them the last time I was in there. I don't think they advertise them as alps, and they are tiny metal cased pots. The only way you could know is they say alps in tiny letters on the case.
This rs pot is not alps pot,just some Taiwan production 100k pot,sounded better then blue velvet with which lost lot of imagining,
This is what I'm talking about, if you can make out ALPs in the photo. They also carry this little black plastic pot (by Alpha) that has a great feel to it and push on/off as well.
there are some issues with the newest pots.(read the reviews) like all metric, no longer 1/4" or 3/8" so dont fit in all uses. just be forwarned but if they work in your appl thats good. I want to see one before buying.
I think they are mostly good for homebrew stuff. They keep them in the little parts drawers at my RS. I think it was Pakprotector that did a thread on them a few years back. The real appeal to me was not so much how they passed a signal, but the fact that they were cheap enough that you could buy plenty and pick out good tracking ones. Most designs I use that have volume control capabilities use the Haller circuit, so the signal doesn't go through the pot on it's way to the amp. In this case, accurate tracking and feel are the most important issues.
My Zen Triode Select uses one, and it sounds fine, as does the Decware. I don't see much on here about the Zen Triode Select, I love mine!:banana:
jaymannaa i have both you pictured, how do they sound black one is 500k,would it do for my cit ii,i have to try it
So is the Alpha or the Alps the better pot and any thoughts on these vs. electronic/remote control based ones?
I think it would be great to have a little thread of sleeper knobs that do as well or at least close enough to the pricey ones out there. Or if not possible, at least have a thread stating why one can expect better from the more expensive stuff out there.
black beauty
There is seller from Germany on ebay familygate selling item alps rk 40312,would it be famous black beauty?anyone opinions on bb?
I guess it depends on the application.
I used the Blue Velvet as a replacement for one of the Radio Shack/Alps pots, in my last 6L6 Magnavox conversion integrated amp. The Blue Velvet (100K) just KILLED the RS pot. Not only did it track better, but the sound was cleaner. Imaging was MUCH improved, probably mostly due to the fact that the two channels tracked so close to each other in level now...
I also recently put the same pot in as an upgrade to my "10-5" amp, I built about 5 years ago. Same result. Better imaging, better balance. It was replacing a standard CTS pot...
Of course, there may be something to be said about the pot being used on the OUTPUT of the line stage tube. I run my input straight into the tube, THEN use the volume control to attenuate the output of the preamp stage, before sending it into the power amp stage. So, the pot is driven from a relatively-low-impedance source (the output impedance of the 12BH7/6CG7/12AU7 tubes I use is somewhere in the 5K range, the way I use them). That could be the difference between my results, and what others have heard, in terms of sonic balance.
BTW: I've recently bought a half dozen of the RS 100K pots- from different RS stores- and unfortunately, I haven't found a SINGLE ONE that TRULY tracks well, all the way down. With most of the amps I build finding their homes with relatively efficient speakers (91dB and higher), this is a real problem. I've about given up using those...
Regards,
Gordon.
Would putting trim pots inline with each pot leg fix the channel imbalance problem.?
Unfortunately, the imbalance isn't consistent, as you go up and down on the volume. Most of them start with one channel "dropped out" at very low volume... and wind up with them relatively balanced, at the very top of the control range. If you optimize it for one volume level setting, then every OTHER level setting is mis-matched...
Regards,
Gordon.
The RS dual pot does have matching problems between sections.
The comment I made concerning the blue alps has to do with frequency
response in absolute terms. It is fuller sounding than absolute neutral.
I am sure it would be beneficial in some applications.
Cheers.
That may well be due to stray capacitance in the pot structure.
That might be the reason why, by me feeding it from a pretty low driving impedance, it caused less "dulling" of the sound, than feeding it from a higher-impedance source. Capacitance has less effect, when driven by lower impedance sources.
IMHO, the dead-nuts-on tracking was worth it. I can make it sound 'balanced'...
Regards,
Gordon.
Watch out for counterfeits, just like everything else.
Yeah, I make sure I order mine from one of the "big boys", who is an actual Alps wholesaler/retailer. They'd get in all sorts of deep doo-doo, if they were caught with counterfeit stuff...
Ebay, etc... uh, I don't think I'll be buying any of 'em there. The lower cost just ain't worth the chance of getting a turd, on something that's as easy to fake as these...
Regards,
Gordon.
