daveyh
I have set of original ALTEC 19 crossovers that I have rebuilt. By rebuilt I mean new L-Pads, ceramic resistors and new Solen capacitors. I have also hammered the rivets and star soldered the ground connections. I have had the woofers professionally re-coned and installed a new diaphragm in the driver.
Here is the problem:
The speaker plays fine with the crossover out and unsecured from the wood case. When I try to screw it in place using one of the four attaching screws to the wood case I get no sound or distorted sound. A little pressure on the plate will cause the speaker sound the come back?? I have checked the other crossover and all the connections are the same.
Does this sound like a ground rivet not secured?
Should I use a drill and use sheet metal screws to secure it and get better contact?
Anyone have any suggestions? This is making be CRAZY!!
