Hi Guys, Good luck for the election on Tuesday. I'll be watching from afar....
Anyway....
I'm pressing ahead with a 620a cabinet style veneered in oak, I see the 604-8k came with the 620b. But I prefer the symmetrically placed network and port so I'm doing that.
I've got a question on the tee nuts to mount the drivers. Front mounting the drivers, the altec drawing has the installed tee nut sitting proud of the baffle, so the driver could be placed on the baffle and located onto the Tee nuts without bolts, then the bolts secure the drivers..... What length of tee nuts do I need ??
Assuming that my ply is 18mm plus veneer, so around 20mm all together. plus depth of speaker frame and gasket. so I guess a 30mm length of tee nut would do. Just as long as its proud of the baffle but not proud enough to be deeper than the driver frame.
Does this sound about right ? or am I reading this wrong ? Thanks All.
