Altec 711A - solid state receiver - refurb
hrtattckcity
AK Subscriber
I recently acquired this Altec 711A solid state receiver in "as-is" condition.
Handsome. Brimming with potential! Yes, I know the lukewarm response to the Altec solid sate receivers.
@Greg Nal was kind enough to send some photos of the 711A manual that he had with schematic and parts list. (will post in thread)
I haven't done any testing, plugged it in with headphones--lights up, one channel is out.
From the underside you can see that one resistor is cracked open, and the sylvania glass bulb self-resetting fuse has a bit of char on it.
I am planning on replacing all capacitors and resistors;
there are some NOS sylvania self-resetting fuses available online--is there a better, contemporary, product that will fill the same role in a better manner? 1A per the manual
Can anyone recommend replacement diodes or transistors if anything is notoriously problematic and should be replaced from the outset?
Schematic and parts list from manual.
