Altec 9849A Crossover Help
Qman
Just picked-up an Altec 9849A without the internal wiring hooked-up. May be one of the earlier ones. Mine has the metal horn, 8ohm 23476 driver/23744 and 414-8B woofer. Anyway, does the H.F. + from the crossover go to L1 or L2 for the compression driver. I know the phasing is different between some Altec models depending on how the horn front and flange are mounted in the cabinet. Thanks.
