Altec 1569 - part 5
Pentode - Triode switching is pretty simple. You need a dpdt switch, and a couple of 47 ohm - 100 ohm 2 watt resistors. Plus, I added in a 22ufd 630v polypropylene solen cap.
Back on the schematic, look at v5 and v6 pin 4, the screen connection. Also note that on each side, pin 4 also connects to its partner parallel tube.
What I see here stock, I do not like, but maybe it is just me. R20 that is feeding the screens, the 250 ohm 5 watt resistor drops down the plate vcc, but is not bypassed. So, on the tube side of r20, I added a 22mfd solen cap to reduce the impedence seen by the screens, and hopefully reduce them moving around as much in voltage.
With the dpdt switch, the two center terminals will hook to pin 4 of each of the sides of the output stage, in place of the connections to r20. So one connection from one center to v5 pin 4, and one connection from the other center pin to v6 pin 4, with no remaining connection to r20. Pick an end of the toggle switch, and hook the side of r20 that had been connected to the pin 4's to both sides of the connections on that end. And again, that end of r20 or the switch connected to the 22mfd solen that the other side of connects to ground (of the solen). Now we have pentode mode again, when the switch is in the correct position to reconnect the pin 4's to r20/solen.
For triode mode, now hook one connection each of the other end of the switch through a 47 ohm 2 watt resistor back to its corresponding output tube pairs plate (pin 3). Be very certain that the side of the switch that goes to pin 4 for example of v5, is the same side on the other end that has the resistor going to pin 3 of v5. You end up with two resistors, each going to one side of the same end of the dpdt switch, both matching the output pairs pin 4 side of the switch, with one resistor to pin 3 of v5, the other to pin 3 of v6. Get the tubes sides/switch interchanged, results will not be pretty.
Keep in mind that pentode mode gives the 80 watts out rating, and triode will probably drop that to 1/2 or more of the above amount. Even though I have not measured it, I would expect the quad of kt90's could push at least a buck and a quarter, maybe more, if you are using this as a high side amp in a biamp setup where the bass is not going to saturate the output transformer. A pair of the kt90's will probably beat the stock quad of el34's in output.
That's pretty much it for bias metering, independent bias, and pentode/triode mode.
On with a few other changes that were made to this amp, and closing thoughts.
The two large black objects in the upper right of one of the photos are angela 47mfd 630v polypropylenes, they replaced c6a and c6b on the schematic, filtering for the 6ccg7's plates. Those are bypassed on the turret board with .01 solens. The HV caps are bypassed with a .01 solen right after the rectifiers.
The third, smaller large black object is the solen 22mfd for the screen bypass, and you can barely see the pentode/triode switch under the left lower corner.
The coax from the phono input was directly connected to pin 7 of v1, with none of the other associated volume control or circuitry hooked to that pin.
There is however a new grid leak resistor of 100k from pin 7 to ground.
My main ground point is the - of the lower hv cap, and pretty much everything stars back to that point. Even a stock altec has some ground loop problems, this one does not - no hum, dead quiet.
This amp is also very quick, detailed, without really getting at all harsh. That said, some people do not like solens, for me in this amp, and my speakers, they are great. For some, with say nose bleed horn speakers, you might want to look elsewhere, but I have not yet heard anything that would make me want to go to some boutique caps in this amp. russian pio's or teflon caps might be fun to try however.
Only mods considered having just reviewed my work from 5 years ago, would be for less than $5 cost to upgrade the two hv rectifiers and the bias rectifier to vishay hexfreds. I also have some 600mfd/500v polypropylene caps, that one may end up replacing the two electrolytic caps currently used for the high voltage filtering.
Since the output tubes are now all split up regarding bias and metering, I am tempted to do away with the 100 ohm grid stop resistors, and attach the coupling caps and the 100k bias resistors directly to the grid of the output tubes. I really do not feel they are necessary any longer, and could be very slightly degrading the signal path. Could you hear the difference? Probably not.....
I stuck with 1/2 watt 10 ohm cathode resistors for a reason, with a tube fart, they will normally blow pretty quickly, I have already replaced a couple. Mills 3 watt 10 ohm would probably be the resistor of choice here, but I would rather not stress the output trannies when you loose a tube, or have a flashover, and let the cathode resistor act as a fuse.
Plus should probably bring the sister of this amp up to the same rev/resto mod level. Right now, this is probably going to be my test bench mule for matching an such, in that this amp has been superceeded by 5 antique sound lab monoblocks in the main system, two of which have only arrived in the last couple of weeks, a pair of asl hurricane dt's. Next project might be a source/speaker switcher so I can switch up to 7.1 home theater from glass to sand with a single switch. Probaby going after a sunfire or parasound multichannel amp, so can still live in the summer heat wise, and cut back on the electric when not doing serious listening. The 5 asl's are pulling down around 2kw of power, and that is not even up on the pipe! I turned off the heat yesterday, and pulled the living room temp up about 2 degrees in an hour!
Are these mods for everyone? Probably not. If I had known how much these altecs would have shot up in the past 5 years, I probably would have rebuilt them more toward stock. However, since I really do not plan on selling the pair I have, that is probably really moot point. The pair I bought were very rough anyway, and in bad need of help. Bottom line, I would rather have the improved performance over the possible future sales price, and if someone that knew altecs heard this one, I believe it might be worth a lot more than a more attractive stock unit.
I did just aquire a scott 272 that is hitting the bench soon, and it will retain most of its original looks, except changing all the old paper caps to illinois poypropylenes.
On the tube rectifiers vrs ss rectifiers, we could argue that point until the cows come home, and it has been argued enough already. However in this configuration, I believe ss is the better way to go. I have probably 20vdc-30vdc more plate voltage available, the load of the 5u4's filaments are gone, and with the metering, individual biasing, and pentode/triode features I believe the higher hv allows more tube options to be used a little better. I'm not sure this amp will ever go back to el34's, I like 6550's, kt88's, kt90's, and this thing will run just fine on even one pair of those. You should hear this thing on a pair of original genelex kt88's! Would love to try a quad of the reissues.
Sorry for a gross hijack of this thread, hopefully some of the madness spewed here will help someone out. Do not attempt any of these mods if you are not qualified to work on HV electronic gear, or at least keep one hand in your pocket!
Good luck, and Good listening,
Brian
