YesOne of your photos of the 23744 shows that you bent the voice coil. The magnet gap is very tight. I don’t see any way it’s not rubbing in the gap.
The two phase plugs will sound different. Many prefer the earlier machined version.
Late model 8G's have the cost saving Tangerines, the rest have the better annular slit, all metal phase plugs.It’s interesting that both are -8G yet have different phase plugs.
Just listen to both speakers for an hour. They are not inside any cabinet; the 16 ohms 20275 diaphragm is replaced with 34647. As they are outside, I was hearing mostly mid-HF, and I personally couldn't notice any difference between the two.Those will work fine.
Interesting, I thought they introduced 605A for cost-cutting (as many people here say so), but my 605A has metal phase plugs!Late model 8G's have the cost saving Tangerines, the rest have the better annular slit, all metal phase plugs.
Is there any easy way to remove the older phase plug and replaced with the tangerine one?
