All ready have them I posted a pic here a few posts back on page 1 of this thread they are 15".... was thinking of building the Z19Have you picked the woofers yet? The 800 crossover would allow for 15 inch woofers. More bass range, less mid.
Considering getting these https://www.parts-express.com/b-52-by-eminence-15-160-15-pro-audio-500-watt-driver-8-ohm--299-2343 to put in the 1235 cabs I just picked up looks like the mids will over lap the horns nicely... yes the crossovers I plan to build will go down to 800hz on the HFHave you picked the woofers yet? The 800 crossover would allow for 15 inch woofers. More bass range, less mid.
Thanks for this info... I am thinking I will build 2 subs and set the 816's on top of them. Originally I was going to use the horns temporarily with my existing speakers and eventually build model 19 clones but then these cabs came up for $35 for the pair so this is now where I will go with this project...That bass driver will work. But, an example with a lower Qts would be more suitable for an Altec midbass horn like your 816A's(1235 is a system of components, the cabinet/horn is an 816A).
This would be a more appropriate horn driver: https://www.parts-express.com/dayton-audio-pa380-8-15-pro-woofer--295-034
Note that regardless of what woofer you load in the 816A, it's going to roll off pretty steeply below 80hz or so. LF extension will be non-existent without a subwoofer or 3, or 4.
Thanks I'm building some L88 bowtie speakers
Just picked these up to go with my horns
