Altec horn speakers
mcgarick
Hello
Anyone familar with the Altec Lansing 890C Bolero speakers?
Is this speaker still considered a great speaker or has time march away for these? I would be using tubes,with em.
Im looking for a GOOD horn speaker.
Thanks
Until recently I owned 890Cs and I consider them the best "small" box speaker ever made.
The key is the superb 406 woofer which uses a 3" voicecoil, the motor from the 414 12" prosound speaker and a dual profile cone. The cone is straight sided near the center then becomes concave towards it's outer edge. Altec engineers spent a great deal of time on this driver and it gives the 890C the realistic midrange of the large, VOT based Altecs.
At 2000hz a horn tweeter comes in, the "mystery horn" which was probably sourced from Heppner. The horn is very clean with no squawk or screech though not as extended on the very top as some.
The 890C is characterized by excellent dynamics for it's size and a smooth robust tone with excellent clarity. Bass is powerful, clean and fairly well extended. I used them with a Fisher 500B tube receiver, a Jolida 102B tube amp and a Teac Tri-Path amp. All worked very well, the speaker needs very little power.
I sold mine because I moved from a large house to a high rise condo and made a clean break away from Altecs to ESLs (I had four sets of Altecs, the 890Cs the smallest, and one set of large JBLs, all gone now). My 890Cs fetched $386 on ebay.
Hi Tom,thanks for the comments,whats the ESLs?
So, the Altec was not very extended on the highs?
ESLs---electrostatic loudspeakers.
I wouldn't say the horn is not extended in absolute terms so much as not as extended as some others. It goes as high as I can hear and has nice air and depth and is by no means dull sounding.
Oh,you'll luv 'em.......
Hello
Thanks
I have them.No complaints really 'cept they could go a little lower.They don't need much power(a 50 watt nominal rating).I'm running them with my 2270 and rarely need to go much above the 9 o'clock volume position.
The horns don't really call attention to themselves,no horn issues to me any-way.
