MadcapLaughs
I just picked a pair of Altec Model 14 Speakers up from Kentucky this weekend. Got lucky and bid cheap on the bay for them, Im minimally invested at this point. The only apparent thing they need is a refoam. Upon closer inspection when I brought them home, it appears that that is most likely correct, I will take them to a tech to do the refoam and crossover recap. However, the cosmetics on one woofer shows a dark spot where cleaner or something stained it at some point, and it needs a new dustcap as well...In your opinion would it be worth it to order 1 or 2 recone kits for both woofers since GPA has original spec recone kits available for the 14? Or would you try to fix the cosmetics on the one woofer...and how? I know the repair tech I am using has restored altecs such as the A7, model 14, 19, etc so I know he has the capabilities.
Again, I do not know the overall functioning condition of the speakers yet, but they do appear to be completely in tact other than missing surrounds. Also, what do you make of one woofer frame being black and the other the original silver/ steel? I think the woofer components are original woofer components, but I'm not too confident about pulling the woofers out of the cabinets to verify.
I at least went through and cleaned the outside of the cabinets with a lemon oil wood cleaner, and wiped down all the dust off the speakers, bottom line is these haven't been used for some time...I really just want soem opinions of what I might be up against as I am prepared to sink some money into these. Thanks!
