Altec VOTT A5 DIY
wsjoe
Well-Known Member
Hi,
This is my first post here.
What can I say...it was love at first sight. BUT due to its low SAF spouse approval factor, I was ready to use the box as my coffin because thank God she said yes! So now it's in the living room.
I just finished my Altec Voice of the Theater super high efficiency speakers. It is the so called A5 VOTT speaker used mainly in small to medium theater speakers.
The only Altec parts are the horn driver 288-16H (with 8ohm voice coil), 515B woofer and N501-8A crossovers. Everything else is a wood replica of the original including the speaker enclosure (box), the wood horn and adapters.
How does it sound? Simply put AMAZING. I have listened to the original A5 and A7 setup with the metal horn and it probably sounded great in large halls for a few thousand square feet building but in my 20x40feet living room, it will sound a bit harsh. It was not my idea but I am following Brayant's advise from Simplexaudio.net. He is the one who started building these wood horns out of Baltic birch plywood. The enclosure is made with 3/4" North American Birch plywood. Anyways, it took me exactly 4 years from idea to finishing and mainly the money gathering/saving part took the longest. It took me also almost a year to finish. The enclosure took me about 1 month to finish and the woodhorns about 3-4 months. Everything has a 3 coat of Watco Danish natural oil finish.
Each speaker weighs about 240 lbs. Efficiency is around 112-115 db/w/m. I am using a loaner from Brayant with 483 tube amp that outputs about 0.74 watts! Yes, that's 3/4 watt! It's an amazing single ended tube that does not have alot of power but that near 1 watt with Sowter output transformer puts out alot more than many amps that put out 20-200 watts. Well, it's not apple to apples but my G-22000 Sansui receiver puts out near 300 watts.
I have decided to go with 300B custom tube amp that Brayant will be putting it together for me. I have done alot of reading but deciding what power and output transformer, brand of tubes and capacitors was very critical in getting "the" sound I want and Brayant was able to define each of those elements very efficiently. At the end, I have chosen to go with newly made Western Electric or KR 300B tubes with Western Electric 310A input tubes and Sowter transformers. Anybody interested in tube equipment, should visit his page http://www.simplexaudio.net/contactus.html.
So how does it sound...?
Effortless, omni directional, wide and sweet. Many horn speakers have the disadvantage of being so pointed and directional. And I have alot of good horn speakers including Edgar's horn, Avantgarde and others. To me my 8 multi sectoral horn sounds just as good or better. I am biased!
I just bought a few Altec VOTT stickers and the original stand. I will update with more pictures and get rid of those pillows supporting the front end of the horns.
My previous speaker was the Yamaha NS-1000 which are reference speakers used in alot of recording rooms. Actually, its smaller brother NS-10 is ubiquitously used in MANY recording rooms. Those berillium drivers are really amazing but they sounded small to my ears.
The cd player is my modded Denon DCD-3560 and Sony SACD player DVP-S9000ES.
The picture shows my previous Pilot 240 integrated amp. Nice tube amp but nowhere near the 483 (special breed of 45 tubes) Brayant's amp.
The 828 enclosure blueprint can be found here along with some more pictures from the Altec Heritage website:
http://www.lansingheritage.org/images/altec/plans/1970's-lf-plans/enclosures11.jpg
http://www.audioheritage.org/html/profiles/altec/vott.htm
wsjoe
Correction, the woofer is not 515B but 515-8G for 8ohms. The 515B is 16ohms!
Thanks everyone!
Beautiful job. Looks like a lot of work and study went in to making them. Very impressive.
You mention that this is your first post? It shows you have 616 posts and registered in 2003.
forum
This is my first forum in the speaker section. I post heavily in the digital section and some in the Sansui section. I will be posting more in the future.
Great job, the horns are something else. This is the best DIY Altec job I think I've ever seen.:thmbsp::thmbsp:
Incredible looking. Didn't even know monsters like that existed for home use. Kudos!
What HH Scott rig you running there?
That's a Pilot integrated amp 240 but now that's disconnected and running a custom designed loaner from a tube guru designer Brayant from http://simplexaudio.net. It's a new site and alot more at his place than pictures.
The work you did on the wooden horns is truly inspiring.
I also love the way you featured some "interesting" grain around the woofers.
Thanks for the great photos.
Some more pictures I just took with Brayant's 483 tube amp and the VOTT label.
The most amazing part is the horn. The crossover cuts at 500 hz and this horn pretty much covers 95% of the audible frequency range. You can feel the woofer with your whole body but the horn is truly a work of art by those genius Altec engineers.
I will need to add a couple of 2x4 vertical reinforcements to the rear cover and horizontal cross member to stiffen the enclosure. The woofer is so powerful that the lower portion of the enclosure is not as dead as possible. I may need to add some sound absorption material inside. The upper half is very very stiff due to the construction of the woofer horn.
For vibration isolation, I chose to use military grade cupmount style made by Brandon Product Groups. Nothing super fancy but it tends to isolate or minimize vibration from 20-100 hz.
http://bpg-inc.com/cupmounts.htm.
Cheers.
The 805 multicell replicas are no less than stunning, very awe inspiring. I've seen and heard them done i a couple different medium hardwoods and thought them a bit too mellow, too far away from the originals. I'm wondering if the birch ply isn't just about the perfect material for those, i'd like to have my ears get intimate with them. Again, thru the looking glass they're exceptional! Sport them with pride.
I'm very curious why the 828 blueprint wasn't followed? Not my intention to pick nits, but those are not 828's.
What you have is much closer to a replica of the 810 cabinet which was replaced by the 825 in the early 50's because of the standing waves and other unwanted sonic colorations cause by the parallel top and bottom horn panels.
bowtie,
You are right, I actually followed the attached 828 plans as much as my woodshop skills allows. The main difference is the angled plane vs mine that comes out horizontally at the bottom of the woofer horn.
Also as you know, Altec sold the driver and crossover and each theater hired local contractors to build the enclosure for them. I have seen about 5 different A5 and A7, and they all look slightly different. Though Altec provided them with the plans, not everyone followed the plans.
I am not very familiar with the 810 enclosure. Do you have that plan that you can post?
I think the birch material does help, as they are supposed to have good acoustic properties. But I think the personal taste has a much bigger factor than that. You may not like these as much as I do. Also the older we get, we lose the high frequency content and alot of the older friends I have, they prefer the original metal horn. It's just my opinion and observation.
as a lover of my A7s I must say those are impressive,, I would proudly display them,,
certrainly four years of well deserved effort,,
Derry
Have you guys seen this 288 monster weapon? I am not very sure on the exact history but I heard Altec participated in some US Army project to use sound as a weapon or some kind of application.
Can you guys imagine how loud this would be?
Yeah, that would hurt.:yes: Definately not nearfield stuff.
