Brad Muller
Those are pretty!!!!:yes:
That might not be an entirely fair statement. Maybe if we said "hornboys" it'd be a bit more accurate. :scratch2:Altec fanboys don't like 'em because of their slightly lower sensitivity.
I'll second that, most were originally built to fill venue's but when Altec realized the Home market was a virtual gold mine they picked up the ball and ran with it. And I'm so glad they did. Love my 604's!!!Make no mistake about this, however. You need a BF'n room to make these things sing, or the music is going to sound compressed.
Wayner
I see that, Good times, Good times.hah. look out! the gang's all here! ;-)
<<<<<SNIP>>>>>
The 413 woofer really is an odd duck among the typical Altec woofers. But odd doesn't always mean "bad".
It's one of the only Altec cone speakers that uses added mass in it's moving assembly, and it's the only non-MI speaker with a ferrite motor on an old style frame, pretty different from any of it's predecessors. <<<<<<<SNIP>>>>>>.
My friend has a pair of Santiagos that I restored 2 summers ago. We think they are from about 1968. These speakers were pieced together from other wrecks. But we believe we have matched the correct HF driver, LF driver, cross-over and EQ circuit required for this model. Cabinets are 9 out of 10. Here is a pic I borrowed off the net to at least let everyone know what they look like:
The 2 important factors is which HF cross-over point was used with the HF driver. Some were at 500hz. We decided that the correct cross-over was at 800hz. We also knew our woofer needed the EQ circuit to smooth out some hills and valleys in the frequency response.
The results are spectacular. You can actually hear the reeds of a sax vibrating in well recorded CDs. Cymbal crash is near real, as are male and female vocals.
Wayner
Hi Bowtie,
How was this "added mass" actually achieved on the 413 woofer ?
Thanks <>![]()
The Model 14 has almost all the goodness of the Model 19.
Just somewhat smaller.
Smaller being a relative term.
Looking like a Model 19 that got shrunk in the wash, these still have a pretty large cabinet but they fare better in smaller spaces.
Great detail, dynamics and soundstage.
Very versatile speakers in terms of what you drive them with.
I use mine with a pair a QuadII amps of about 18 watts each
but have driven them in the past with a pair of modded
Akai M8 monoblocks, of about 3.5 watts each, with no problem.
I also use them with my Revox solid state system - 110 wpc. (or 120 - don't recall exactly right now)
The mantaray horns in these are really very nice.
Art
Howdy Earl! Not sure how i missed your post until now.Hi Bowtie,
Thanks <>![]()
Good to see you here B! I guess we happened along this old thread at the same time.Hi Earl,
Seems Bowtie missed your Q, so I'll pitch in.
413s had an incredibly thick (~1/8") painted aluminum dustcap in addition to the heavy cone that was made much like the 411. The only other use of those heavy dustcaps I've seen are on a pair of 417s I've got in some 123x wedge monitors (unpainted in that app). Charles Clark has also come across them on special-duty 417s.
Those 417's......................... were they tweaked for bass guitar apps do you suppose?
Curious about the 417 motor structure, particularly gap depth, and if it's possible to load one into a sort of "magnum" version of the 414.
