Skip to End for question...
So I have an older receiver, Pioneer SX-828 (that markthefixer did a great job on!), and we've moved houses. What used to work for FM, the cheap plastic 300 ohm dipole antenna, just isn't cutting it any longer as the receiver is in the full basement. The SX-828 has both 75 and 300 ohm hookups.
I looked around and saw the Stellar Labs 30-2435 had pretty good reviews and was cheap, and to go with it I ordered a Channel Master CM-3203 balun/matching transformer. With some Menards pre-terminated RG6, I figured I'd be all set. Turns out, I was wrong...
First I tried hooking it up with the spade connectors on the CM to the 300 ohm on the receiver. That got me basically nothing, even worse than the dipole. So I tried hooking the spade connectors up to the 75 ohm on the receiver and got almost nothing, and nothing real clear at all. Then I actually read the sheet that cam with the Stellar, and low and behold, it says right on there: Output: 75 ohm.
Looking at the CM balun, it's designed to take 300 ohm antenna and convert it to 75 ohm for the coax homerun/end equipement. Doh!
So really all I need is a coax to spade converter, which I thought would be plentiful. After 15 minutes of google searching, all I can find are 300 ohm to 75 ohm baluns like I already have. I realize I can cut the coax end off and use the shield as a ground and the inner conductor as my feed, but I was hoping for a more finished install here.
End: Does anyone know if there exists a coax to spade converter that will allow me to screw the coax in (normal F connector) and output to spade, which is what the receiver needs? There must be something like this for older receivers, right?
Chuck
Chuck
