Here are some specs if it helps:
ONKYO TX 8511
Power Output (8 ohm, 20 Hz-20 kHz, FTC) 100 W/Ch
Dynamic Power* 140 W/Ch/135 W/Ch
THD (Rated Power) 0.08 %
Frequency Response 20 Hz-30 kHz (+/- 1 dB)
S/N Ratio -
Phono(MM) 80 dB (IHF-A, 5 mV input)
CD-Tape 100 dB (IHF-A)
Phono Overload (1 kHz) 120 mV RMS, 0.5 % THD
Tuner Section
Usable Sensitivity -
FM Mono 11.2 dBf, 1.0 uV (75 ohm IHF)
FM Stereo 17.2 dBf, 2.0 uV (75 ohm IHF)
AM 30 uV
S/N Ratio (FM Mono/FM Stereo/AM) 76 dB (IHF-A)/70 dB (IHF-A)/40 dB
THD (FM Mono/FM Stereo/AM) 0.15 %/0.25 %/0.7 %
FM Stereo Separation 45 dB at 1 kHz
Dimensions (W x H x D) 17 1/8"" x 5 7/8"" x 12 11/16""
Weight 19.6 lbs./8.9 kg
PIONEER SX 780
Power Output: 45 watts per channel RMS into 8 ohms.
Harmonic Distortion: Less than 0.05%
Intermodulation Distortion: Less than 0.05%
FM Sensitivity: 1.8uV
FM Capture Ratio: 1.00
FM Harmonic Distortion Mono: <0.07%
FM Harmonic Distortion Stereo: <0.15%
Dimensions: 19 x 12.5 x 5.5
Weight: 24.75 lbsc
if your main source is phono and FM, then I think the Pioneer
If your main source is Digital then either.
I like the looks of the Pioneer better, but the Onkyo is more "convienent"
Really the best thing you can do is try both.
