Thunderknob
Just joined Audiokarma today I effort to fix my amp. My am2800 hasn't been used for years. I set it up again recently, but it has developed issues.
Everything was operating fine until it started pegging the right side meter with intermittent full volume static. Even with the volume turned off, every ten seconds, or so, it makes extremely loud crackling and the right side meter flickers and pegs momentarily. I took the cover off and I can see and hear the relay with the points flicking and clicking.
I had trouble with the on/off button sticking, last year. I took it apart and freed the stickiness and resurfaced the contacts. I saw a video about how a bad switch was causing the red light to come on, but not power up completely. My switch is fine now, I am sure. I've rebuild plenty of switches. Also, I noticed the meter light is burned out.
The amp has never been cleaned or serviced. It's not dirty. Nothing gets warm. I don't know what's wrong. Hopefully someone out there has seen this specific problem, the intermittent full volume crackling and the flickering of the right side meter. I have access to a volt meter that will read millivolts, but I haven't checked the adjustments shown on Uribe yet. I haven't used that spray cleaner yet either. Everything was operating correctly, until this major noise issue. It's not a tuning problem, I pretty sure. Something has failed. I'm not an electronic geek, but I'm ok at soldering. Help!
