I think we'd all be surprised if there were some thermal imaging available. Nelson seems to do a good job figuring out what's required in the way of heatsinks.OK thanks they look huge against the transistor. I didn't realize heat could efficiently dissipate that far out .
Just discovered this thread - I am wondering if these would be OK with a pair of Polk monitor 40's .. 90db efficiency ... the kit looks wonderful.
Sachin-
I meant to ask earlier. The ACA build specifies a 19V supply. It looks like you're using one of those push-button "angel eye" switches that seem to be the rage these days. Near every one I search for is only spec-ed for 12V. What is your switch rated at and, if more than 12V, where did you get it? I'm trying to finalize my parts-list and am thinking of the angel eye switch but can't seem to search/find one that works.
Hi Joel,
we bought that switches locally.They are 24V.I think they are also available at ebay
Regards,
Sachin
Just thinking here....:scratch2:
How about placing one of these Optical switches, mounted in a small hole or even placed along side the faceplate. A movement of your hand across the sensor would power the relay to interrupt mains power to the amp. If not already available, the components could all be on a small PCB.
Sachin-
1) The soldering on Q2 doesn't look that great (is the right leg even connected?). Try reflowing all those joints for Q1 and Q2.
2) Check to make sure you're actually getting +19V off of the blue wire when the power supply is hooked up (it is a 19V supply, > 2A, correct?).
3) Are those 3W resistors (R1-R4) toasted or are they just dirty from grubby fingers? They should be elevated from the board but it's probably too late if the leads have been clipped.
4) Is the board mounted on standoffs or is it just supported by the MOSFETs and clamped on the opposite side? If it's not on standoffs, you could be shorting things out if any of the soldering is touching.
