dspear99ca
I picked another junker console amp off of eBay. It's out of a Magnavox console, a 93-02 amp. It sounds good initially, then the sound deteriorates, first distorting horribly at higher volumes, then gradually the distortion happens all the time even at low volume. The PS caps have been replaced and look relatively new. The distortion happens in both channels so I'm thinking it's gotta' be a power supply issue. Would something like a bad solder joint on one of the filter caps or filter cap grounds cause this? A bad cap? There's no hum or anything, the sound is just all broken up like what you'd normally get if you removed power from the amp and the voltage drops off.
Dave
Dave
