triode17
The dummy loads are a good idea. I have not done this, but I always leave the preamp turned down all the way when I am not using it. So if I forget to change the switch, and I have many times now, as I turn it up slowly and nothing comes out, I stop immediately and correct the situation. As long as you don't crank it up high, no damage happens.To clarify: Is the recommendation to put a 100-150 ohm resistor across each amp's output (for example + and - on the amp's speaker wire socket) permanently so that it acts as a dummy load and protects the amp (specifically its output transformers) when the amp is on but speakers are not connected to it? But when the speakers are connected, the effects of these resistors are negligible and they can be left in place, no need to disconnect them?
I understand that these resistors can be incorporated on the switch side, but the amp side is more convenient as this way they only work with the tube amp and not any amp connected to the switchbox (or the input of the switchbox to which they are added).
