Amplifier Opinion Poll
Two amplifiers with the same wpc output and comparably low distortion will sound alike.
  • Yes, watts are watts.
  • No, not unless they are identical.
  • Need more information.
  • All amplifiers of decent quality sound alike.
  • All amps should sound alike, but don't.
Results are only viewable after voting.
Status
Not open for further replies.
Now we know where you are obtaining your hot gas information. I would remind you that Floyd recommended in his book that individuals perform their own dbt/abx tests and account for NO confound variables, Only for sight. Do you think there is any marketing, agenda involved??? Let's see.
1) He expects untrained individuals to perform sophisticated testing.
2) If he only understands what he printed, he knows virtually nothing about testing or has an agenda.
3) Where are the peers that rigorous testing needs. One is virtually certain to post a false conclusion as one does not understand even
one other confound.
This is largely irrelevant to the point in which I mentioned Floyd Toole, which is that there are psychoacoustic effects. Do you disagree?
Your response answers none of the other questions in my post.
Regarding point #3, above, have you published your peer-reviewed double-blind testing?
If so, can you provide a reference so we can read it?
Every woman I've met in 50+ years of owning audio gear that had an interest in this "passion" had better audio acuity than any of the males. It's at least partially physiological. The bones in a woman's inner ear are smaller and more sensitive. This is a fact with those who have any knowledge of anatomy and physiology.
OH GREAT. now instead of the new benchmark amp, i'm saving for sexual reassignment surgery. the gf will be so disappointed.
a couple serious points:
seems that human trials are both the main point of this discussion, and it's downfall - while the differences that can be heard are what's at stake, one cannot remove the human element from the trials, and our minds are not computers, when we think one amp sounds better than another, that could not only be due to a non-linear response from the amp that only your ears prefer, to some random element of neurochemistry, beyond control or perception.
also it occurs to me that if you need multiple double blind tests to discern the difference between a $2,000 amplifier and a $8,000 amplifier, you should probably go home with the $2,000 amp and $6,000 to spend on deep dish pizza or speakers, more records, whatever. it seems clear that there are differences, but they're not typically major when considering products in a similar class.
Preference indicates prior knowledge so regardless of what one might prefer, the ability to distinguish ascending levels of realism and therefore accuracy is not exclusive. Neither is identification. Topics are.
Thus far, my own testing has been negligible. However, the accounts of those who have done extensive testing, such as...
...are notable.
And yet, the "Shuffler" only compares one speaker at a time. Mono signal. As for me, I find imaging to be an important characteristic along with neutral response and consistent directivity.
Also, while I'm not a fan of Martin-Logan hybrid electrostatics, they were rated pretty low using the shuffler. The problem is that dipoles aren't necessarily optimized in the same position as monopoles. I had a conversation with Sean Olive about this and he didn't seem to understand.
I also feel ABX testing may be flawed.
There is one aspect of ABX testing I haven't heard mentioned in this thread. It is assumed that the ABX box itself makes no difference in the sound quality. The usual "assumption" is that "well, there are just a couple of switches, contacts and wires, how much difference could that make?"
Therein lies the lack of scientific method. Assumption proves nothing. Real science uses controls that have been established. Years ago, Frank Van Alstine observed that the boxes necessarily have common grounds to prevent overt switching transients - anyone ever change out interconnects with an amp playing at high gain? So now, you are not comparing A vs B. You are comparing A+B vs A+B and with amplifiers you end up mixing the feedback loop components. Of course everything sounds the same! There's a really funny interconnect comparison test detailed on the Elliott Sound website. It goes like this: connect a source like a CDP via a Y-adapter using two different sets of interconnects attached to different inputs on a preamp. You can then switch between the inputs and compare the source via either cable A or cable B and evaluate any "differences". Right? The fallacy is that when you use a Y-adapter, you are once again using common grounds. I have a capacitance meter and what you end up with is the summed values of both cables at either end! What a joke! You're not "comparing" anything. Of course A+B sounds exactly like A+B.
In response to that, FVA designed his own $1000 ABX box which uses active buffers - unlike the common switch boxes "assumed to be perfect".
Bogus science results in bogus results.
I think if two amps sound alike, or at least close, It has a lot to do with the voicing the brand chooses to give the amp. If two amps are designed to produce a warm sound, or a slightly bright sound, then they may or may not sound alike. It depends on the details of the voicing.
If however two amps are designed to be transparent, Then, High quality amps of most designs, Whether tube, SS, Class A/B, or Class A, might sound the same when kept out of clipping.
Bottom line IMO is two amps can sound different. That said, I think overall the difference between well designed amps is much less than Phono cartridges, Speakers (of course), and other sources like FM Tuners and CD players.
Myself I think, "voicing the sound" might be more in the minds of nowadays users than in the minds of the designers.
Now, excluding the tone controls, where do I find the voicing circuitry in these SS amps?
No... No one knows what the other persons set up sounds like. Many assume there is some similarity and a few have a wonderful sound far more superior than what new can get you. Social behavior patterns of acceptance dictate how a group responds collectively.
Personally I have no doubt that amplifiers might sound different from one another and that someone can differentiate between them by way of a combination of learned listening and psychoacoustic phenomenom , which both probably can never really be separated in the listening experience.
I personally think most well working amps sound good and don't get too concerned as to whether they might or might not sound the same.
I don't think that's assumed at all; I certainly wouldn't assume it. Indeed, any study involving some experimental apparatus needs to verify that the apparatus isn't confounding the results. Not doing so would expose a trivial basis for rejecting the study.
That said, I did a quick search for verification that this had been done in audio ABX testing, and didn't find any, but it was a very quick search. Perhaps my search-fu is weak this morning.
Yes.
The question was first presented to you, so please stop the misdirection.
Why would one suggest such a test when one knows that the public cannot possibly perform the test properly. If it is to mislead the public, knowingly or not, or for marketing purposes or not, it has to do with Floyd's credibility, so yes it is relevant and I believe the public has a right to know.
As I presented to you in at least one other string, you now know at least some of the confound variables, from the medical experts. So the information is not new to you. And the confounds are different in sighted vs dbts. So why would you want me to submit any information to a group who not only do not consult the medical experts, but who accept the obviously flawed dbts. It could not be that companies are funding these individuals could it... thus a huge conflict of interest.
I have to wonder why do you continue to ignore those confounds and obvious, fatal dbt flaws.
I'm not sure what that has to do with anything I've written here, other than mentioning Floyd Toole. Again, I only mentioned him only as an aside to my point that psychoacoustic (or psychophysical) effects might account for perceived differences between (say) "audiophile grade" capacitors. Do you disagree?
So you are a computer programmer, completely out of your field, and use terms "entirely identifiable", "nearly-magical", and "not based on physics" when those are completely out of your field of expertise.
I'm employed as a computer scientist, though I've been employed as a programmer in the past. However, I am a computer programmer and it's what I do. By way of analogy, think "physicist who also does plumbing", if it helps.
Thus, terms like "entirely identifiable", "nearly-magical", and "not based on physics" are very much part of my field of expertise. Magical explanations for behaviour are frequently attributed to computer systems, usually due to misunderstanding. Example: I had a client who believed computer viruses were caused by sneezing on floppy diskettes. Really.
Yet you consider yourself an expert by condemning John and me.
I haven't condemned you or John. I'm not sure why you think I have. Could you indicate where I've done so?
I haven't claimed to be an expert in anything, either. You appear to be reading more into what I've written than what I've written.
I wrote:
That the fundamental properties of electronic circuits are inductance, resistance, capacitance, and susceptibility to and/or generation of noise?
And that proves there is nothing else?
What else is there?
Please provide citations.
With the logic you use, a battery does not exist because it is not even mentioned in my engineering textbook. If there was a battery mentioned, temperature would also not affect its characteristics since that information is also not addressed in my engineering textbook. Of course a battery does exist and temperature does influence its characteristics.
What does that have to do with the fundamental properties of electronic circuits?
I wrote:
it must be emphasised that it is due to entirely identifiable, explainable, and measurable electrical properties
So you are back tracking from the term "measurable electrical properties".
Not at all. Are you claiming there are unknown electrical properties, or known ones that are so subtle that they are unmeasurable -- thus not even identifiable, let alone quantifiable -- but we can hear them?
It reminds me of claims for extrasensory perception, ghosts, telekinesis, dowsing, etc., that are perceivable (i.e., personal accounts certainly exist) but never seem to be measurable or repeatable under controlled experiments. One explanation is that our scientific apparatus and processes are unsuitable for investigating the paranormal. Another explanation is that such perception is purely psychophysical and without any phenomenological basis outside mundane physical processes and human psychology.
There are obvious similarities to claims about subtle audio effects. I make no claim as to whether paranormal phenomena exist or not, nor do I make any claim as to whether unmeasurable-but-hearable audible effects exist or not. However, this is clearly a case where extraordinary claims -- whether for unmeasurable paranormal phenomena or unmeasurable-but-hearable audible effects -- require extraordinary evidence.
I wrote:
One has to understand material involvement and manufacturing technique in order to what?
it is called physics, what you claimed to understand since you used the term.
You didn't answer my question.
You appear to be conflating causes with effects. Material and construction are causes; differences in electrical properties are effects.
But you leave little doubt, from comments like I quoted above etc, that is what is occurring.
I'm curious to know what you think is occurring.
And the horse is being bashed into glue again.
How many times can we have this same debate ??
Seems infinite times.
Frannie
Sure it is by the likes of guys like Arny Krueger and found in *studies* like the incompetent one by Meyer and Moron regarding high resolution recordings.
If there are recognised studies that establish the non-confounding nature of typical switchboxes, then there would be no need to repeat such studies, because switchboxes (properly constructed and used, we assume) would be non-confounding.
On the other hand, if there are recognised studies that establish a confounding nature of typical switchboxes, then Krueger, Meyer & Moran (I'll assume "Moron" was a Freudian slip, yes?), etc., were indeed remiss for not considering them.
If there are contentious studies whose results regarding use of switchboxes are inconclusive, then subsequent results using switchboxes may be contentious.
Of course, what is contentious, inconclusive, conclusive, or outright wrong, is itself a source of contention.
No one ever said science was easy.
Status
