Tube Radio
I have a Carver TFM-15 amp and a Scott LK-72 amp.
I used one then the other to drive a pair of Altec 811B horns.
the Scott sounds brighter on the horns, but does not integrate well with the Carver TFM-35 amp on the Midbass drivers.
The Carver TFM-15 doesn't sound as bright, but integrates much better with the TFM-35.
By integrating I mean how the midbass drivers and horns sound around the crossover frequency of 1.2 KHz.
There are a few possibilities here.
1. The different amp technologies.
2. In reference to #1 the Scott may have to be turned up louder to better integrate with the Carver amp at the crossover frequency.
3. The fact that tube and solid state reproduce different harmonics of the original signal.
4. The efficiency of the horns makes differences in amplifiers more noticeable.
Here's the output waveforms as measured using one channel of each amp connected to the Altec 811B horns. Loose connection with the alligator clip lead which is why the trace for the Carver amp looks like it does.
The Scott has a little hash on the positive peak of the output waveform. Not sure what causes that hash. I did have my xbox360 running along with my HDTV (all near the amp when testing) and cellphone charger (known source of RFI) so maybe one of those caused the problem since I was using unslielded leads to connect the amps to the scope.
