If the chassis is twisted you might be able to straighten it by loosening some screws that attach the main frame to the front and back chassis, no need to unscrew all the way just loosen. Then see if some slight pressure gets rid of the twist. If so you can try to work it out, then clamp the parts in place and tighten up your chassis screws. I have had some success fixing slightly bent frames.
