audiodon, the bulbs are already painted. the paint has heated away over the years, and i just want to refresh it.
and i thought the light went *in* the side of the dial glass, which is how the letters are illuminated so beautifully. the bulbs were oriented to shine directly into the side of the dial glass, and there is the foam on the outer surface and these two rubber blocks on the inner. the side of the glass is the *only* place for the light to get in there...so i don't understand "wrapping the edge"...
fisherdude, i am glad i didn't break it, but i was using wood in a way that would break the wood first, not allowing me to put that much torque on the glass. i also worked it very, very slowly. i didn't want to cut anything, so i didn't use a blade...mostly because i didn't know what that stand-off material *was*. however, point taken.
merrylander, that's where i am headed. i got all the adhesive off, and am going to finish cleaning the glass tonight.
bobby, i'm just starting my refurb. going to get it clean and shiny first. i have all my tubes, at least to start (still not happy with two of my four 7868s), my PIO caps, and some of my resistors. i'm making an order later in the week once i compare what's actually there to what's on the schematic (and differences noted on the schematic).
