Mike Sweeney
Well-Known Member
The popular opinion is to soak the heck out of the pot with DeOxit, swish the control many times side to side, then rinse to wash out the "gunk". And to be fair, that does seem to work pretty well.
I now use a method told to me using the needle version of DeOxit and a more targeted way.
The soaking can cause unintended issues like "greaseicles" forming down from the pots over time. I had to take my 2285B apart a year after the rebuild to replace two pots.. ALL of the pots have grease running down the sides because they were sprayed and soaked trying to clean them. This softened the internal grease but didnt remove it. And it softened it to the point that some ran out of the pots over time. You can see this in the picture along with the phenolic boards of the pots still wet with DeOxit a year afterwards
IF I could get the pots taken apart easier, I'd put new DeOxit grease in them. In this case, since I had already used DeOxit spray, I used electronic connection cleaning spray then use FaderLube to put some lubrication back into the tracks
