Ronald.C
So today my Sansui AU-9500 presented the same symptom of some Forum friends.
The left channel when heated, did not notice the problem with it cold, began to make noises that look like the sound of static.
I cleaned all the potentiometers, the left channel driver board and the F2006 board with clean contacts and the noise stopped, after 5 hours listening to the noise returned. What I realized is that the volume does not interfere with the noise, nor any selector switch, the noise continues and only when I turn it off.
When it cools the noise disappears and only comes back when it reaches a certain temperature!
My question is this: Has anyone been able to find out the real culprit in this problem? Or did they all recap the capacitors? I do not have the intention at the moment to change everything, so I would go straight to the source of the problem!
Here in Brazil it is almost impossible to find nichikon capacitors, and buying on Ebay is very expensive because of shipping! So I would like to change as little as possible!
