tomlinmgt
Lunatic Member
Glad to hear you got things sorted out and Morphine is a great choice of music for the 22's. :yes:
As far as upgrades to the interface units..not a lot that can be done there, actually. The few caps that are in them only influence the 80Hz cut off filter circuit and only come into play when the switch is engaged and the main circuit has a single resistor which can be upgraded to a higher quality unit. Not sure what the prior owner means by "rebuild the bias amplifier". I've done quite a bit of research on mods and restoration for the 22's and its interface unit and have never heard of that. There is a bias pot in the interface and its setting can be adjusted which can increase or decrease output, but no "bias amplifier" to rebuild or modify or whatever. The 80hz cut off switch should be inspected to make sure there's no corrosion or bad contact as its part of the main circuit. I changed mine out for a more robust unit...as well as the speaker binding posts.
