I have a fully functional DBT and recently tested it with a small Lafayette LA-224T solid-state amplifier. The amp is rated at a 30-watt power draw and has a relatively low output.
When I connect the DBT, there’s no light at all, regardless of which bulb I use — I’ve tried 25W, 40W, and 75W bulbs with the same result.
What’s happening here? This is the first time I’ve powered up such a small amplifier using a DBT, so I’m curious whether the draw is simply too low to illuminate the bulb, or if I might be missing something else.
Any thoughts or explanations would be appreciated.
