I have a Sansui 5700 that has an open .33 ohm dual emitter resistor .
I am waiting for some to be delivered but it seems the eBay seller is slow to ship.
So I have parts amp that has .22 ohm dual emitter resisters and want to know If i could use those till the correct value come in. I was reading that the bias would need to change and I could use the new value if I got the new correct bias value.
So with the .33 ohm R's the bias is to be set at 3.3mV . using ohms Law I came up with a .1mA current if I did that correctly.
So with a .22 ohm and using the 3.3mV I get .15mA , so here is the question, what is the new bias voltage beset at? 3.3mV is what it should be with .33 ohm,So what should the mV be with the .22 ohm ? N to sure what values to use in the formula .1mA or the 1.5 mA .
Athanasios
Athanasios
