Another flexi rack joins the ranks
240sx4u
Lunatic Member
So, I was sick of having my gear haphazardly stacked all over the damn place so I build this;
Pretty unreal how easy it really was. I have no saw guide or table saw so cutting perfectly straight shelves wasn't in the cards. I created a template from .5" mdf that I already had and made it as good as I could get it then used a router with a straight cut bit and a bearing on the end to make copies. Total time invested minus finish drying time is well under 6 hours.
I used 3/4" rod, and birch plywood. The top is two pieces sandwiched together and the bottom piece has 3/4" holes drilled in it so it just sits on top. The nuts/washers are for leveling only.
This thing is a bit more "Flexi" than I would like, but for about $80 bucks or so I sure can't complain. It is 4' tall or so. I cut down 6' rods.
I suck ass at woodworking, so I am pretty stoked about this. I also attached a picture of my $50 expedit I got off of craigslist, which sits to the right.
Evan
Evan
Let me be the first to call Bullshit on that.
I think it looks great! :thmbsp:
Nice work!
Love those tube amps!!! That looks sweet.
You dont suck that much ass, give yourself a break!
that does look excellent. nice detail on the front of each shelf. I would still like to attempt a build like this.
Nate, those are my Dynaco MKIIIs. They are turned backwards so all the connections aren't visible.
Thanks guys.
Very, very nice job for someone who claims not to be a woodworker! It just shows you how easy some things are once you take the plunge.
Awesome job!
you say: 'This thing is a bit more "Flexi" than I would like,'
I'm guessing that has to do with three legs rather than four, but I do like the looks of the tripod version. Nice work.
It would have been a nightmare to level with four legs on the floor that it is sitting on. The entire thing is sloped. That flexi rack has a 2" wide piece of 1/2" plywood under the front edge to level it!!! I think the concrete was poured to keep fluids running to a floor drain which is behind that wall.
Don't get me wrong, the rack really isn't very flexy but its not as stiff as I would like. Next time I buy a sheet of birch ply I will build 2 more shelves which will stiffen it up a lot. There is about a foot between each shelf. I figure if I run out of room Ill move that TT to a wall shelf.
Beautiful Job
Looks really nice Evan, and I imagine a couple more shelves will stiffen that up even more. The Oracle looks really nice sitting on it's perch, overseeing its domain.
Nothing wrong with your woodworking skills thats for sure.
Regards
Mister Pig
The otter one may be reinstated pending an investigation. He's a suspect for the murder of 212 baby fishes.
