Another KA-3500 restoration thread
analogwisdom
When in doubt, stuff in a WIMA
Hey y'all. I'm a big Kenwood fanatic, and wanted something relatively simple, so I've had my eye on the KA-3500 for a while. I found this unit on Fleabay for a good price, of course the seller was a little enthusiastic about its operating condition...
Here's the specimen, arrived yesterday. Cosmetically the outside is in great condition, sadly the googly eye on the other side was missing. Oh well. Fired up on the DBT!
DC offset is pretty high on both channels, around 75mV. It also had a pretty bad constant buzz no matter the volume level, that would temporarily go away when turning the speaker select switch. You can probably take a guess what remedied that buzzing... Good 'ol D5 on every single pot and switch.
It still sounds like crap, though, and just completely cuts out when any kind of bass hit happened. Let's get 'er taken apart and get a closer look...
Not too crusty. I've definitely seen worse around here! A few dried up spider friends were found.
Yeah, I'm taking this thing down to the bare chassis. I'm really inspired by the work of Hopjohn and also Prime Hifi on YouTube. I'm still very new to this and have a long way to go to get to their level, but if I want to call what I do a restoration, then I want it to be actually restored!
Here are the preamp boards:
And here is the power amp/power supply board without the heatsink:
I took the batwing output devices out of circuit and they tested good still. That's a relief! I also tested the transistors in the muting circuit and one of them was no good. That'll be replaced.
I think I found one of our main culprits for "it no worky", though...
Gotta love that glue they used. Not surprisingly, this guy tested horribly. This and the other caps on the power supply section all had super high ESR.
Stay tuned for more, I had most of the parts I need already but got some stuff on order based on hopjohn's resto thread. I'm gonna replace all the electrolytics, of course. I will also take stock of what else I have and replace other parts, as well. Don't be surprised to see a ton of WIMAs on these boards ;)
Cheers!
Concerning the main filter caps, and elcos in general. We know now that the manufacturers have been saving money by way of undervaluing caps by +/-10%. We need to keep this in mind when choosing new caps.
When I worked on my Marantz MA500's all of the old 10000µF filter caps were down to around 9000µF. New 10000µF caps will measure somewhere around only 9100µF. I bought a bunch of UCC SMH 12000µ caps and they all measured about 11000µF.
Point being I would probably go with 8200µF in that amp, you will probably end up with something around 7400µF.
Cheers,
James
Cheers,
James
Thank you for the suggestion, I didn't even consider that. I will grab some higher value main filter caps.
Thanks for posting this process.
I picked up a KA-3500 on the cheap on FB a while back, and am using it fed thru an active low pass filter @ 80hz to power 8" woofers in a T-line. It's working well in that application, but it'll likely need some freshening and recapping at some point.
It's a great amp! Worth the time to rework. Mine just came back recently from another extensive rework by another member here (who is also a friend near me) after it had developed an intermittent left channel crackle. He also replaced the main speaker jacks so now I can use banana plugs, which is a nice upgrade. Very powerful amp for its specs, in my smaller rooms I don't get over 10 o'clock on the volume knob when playing line sources. Good luck with your restoration!
Oh yeah, and unrestored as of three years ago, I was getting upwards of 50mv on both channels, the first sign that things were aging out.
That upgrade is definitely on my to-do list if I bother to open it up! Honestly, a "good issue" that I'm facing, is that since picking up the Kenwood a Sherwood RX-4109 receiver with banana plugs, and a Phase Linear DRS250 integrated amp have fallen into my lap. The Phase Linear will likely need refreshing as well....at least I'll have suitable backups while I freshen the Kenwood. I doubt the Sherwood is in quite the same league, but it should do below 80hz for a while (and there's a remote control available). :cool:
I have no idea what this means but I am glad the Kenwood is working well for you lol
It just means there's an active crossover in the mix, and I'm only using the Kenwood to drive the woofers in the lower range below 80hz, while bi-amping with tube amps for the mids/tweeters. The Kenwood has great bass for a modestly rated amp.
I found this photo on a listing for a restored KA-3500 for sale (not affiliated)... I'm confused here, is there some kind of mod this person was trying to do? To me it seems like they wanted to replace the original mylar caps with WIMAs but instead of getting ones with proper lead spacing this was their "solution"... please correct me if that isn't what seems to be going on.
looking at pics of mine, the only thing that makes any sense of that is that they blew out the pads/trashed the traces when they removed the mylars
That makes sense... I haven't f'ed up any pads or traces on this one (yet), but it's also a LOT easier to remove old parts with the board completely removed from the unit. This is the 2nd Kenwood I've worked on, and I can tell they both have pretty delicate pads/traces in certain spots. (lifted more than a couple on my KA-7300 due to inexperience)
I think so far I prefer the ease of working on boards when you fully disassemble the unit. I'll gladly take the annoyance of taking longer to put it back together over trying to maneuver around boards that are still inside of the chassis. (as long as I don't 'eff up by putting it back together the wrong way, but I make sure to take plenty of pics and vids lol). Plus you can deep clean a board so much better when it's outside of the unit.
i didn't totally remove mine but i did disconnect the power indicator and the power and ground to the flat amp then i had enough slack to stand the main board on end.
stupid design.
stupid design.
Yeah, part of the reason I picked the 3500 was I figured it'd be a easier/simpler designed unit for a newbie like me to work on, didn't realize how messy it would be inside. I think I'll be able to handle it, not the most complicated thing ever, but also just not the breeze I figured it'd be.
xraytonyb did a video on one and said it was a great design and easy to work on.
i beg to differ :rflmao:
Cheers,
James
So I had already ordered the 6800 before you made this reply, but both sets came today.
The 6800uF KW's are actually measuring above spec - 7250uF and 7300uF.
The 10000uF FW's are measuring at 9100 and 9150.
Which set would y'all put in? In Hopjohn's resto thread he upped it to the 10k but I'm not sure which ones to go with. Seems like the KW's measuring above spec would be plenty good enough.
Finished up work on the small section of the preamp/tone board last night. Here's the before again for reference:
index.php
And after:
The buttons were cleaned with D5 then shot with additional F5.
I replaced the signal path resistors with matched metal film based off hopjohn's resto thread, and I went ahead and replaced other resistors that I had values on hand for while I was at it. I was not expecting how small the Vishay SFR16 resistors would be... lol
All electrolytics replaced with Nichicon UKZ and a UES 'cuz that was best fit I had on hand. WIMAs were also used (of course), replacing electrolytics when applicable and original Mylar caps as well. All ceramics were also replaced with TDK MLCC C0G ceramics.
From hopjohn's thread, updated with what I used, for reference:
Preamp X08-1530-00 (Small Selector Board)
Cd1/Cd2 22uf 10V > 22uf 50V FG Feedback Loop 22µF 50V UKZ
Cd9/Cd10 100uf 10V 8mm > 220uf 25V PM 8mm Emitter Bypass 100µF 16V UKZ
Cd11/Cd12 3.3uf 50V > 4.7uf 50V MKS2 Signal Path 3.3µF 63V MKS2
Cd39 > 47uf 16V 8mm > 47uf 35V KL 8mm Local Filtering 47µF 16V UES
Rd1/Rd2 2.2K > 2.2K 0.5W Yageo metal film Matched Signal Path 2.2K 0.5W Vishay SFR16 matched, Rd17/Rd18 additionally replaced
Rd23/Rd24 1K > 1K 0.5W Yageo metal film Matched Signal Path 1K 0.5W Vishay SFR16 matched, Rd19/Rd20 additionally replaced
and my additional replacements:
Cd3/Cd4 1000pF Mylar 5% > 1000pF 63V FKP2 2.5%
Cd5/Cd6 3300pF Mylar 5% > 3300pF 100V MKP10 2.5%
Cd7/Cd8 27pF Ceramic 10% > 27pF 100V FG C0G 5%
Cd13/Cd14 22pF Ceramic 10% > 22pF 100V FG C0G 5%
Rd17/Rd18/Rd56 5.6K 0.25W > 5.6K 0.25W Vishay RN60
Rd7/Rd8 10K 0.25W > 10K 0.5W Vishay SFR16
To quote hopjohn yet again:
Clean the solder side of the boards. Flux hides bad joints and you need to be able to inspect the originals and your own. Take pride in clean boards.
To that end, here is before and after of the solder side of the board, every joint has been redone. I will go over it again later before re-assembly as well, just to double check my work.
A clean board really is satisfying. It's hard to get on a still image how much shinier it is after cleaning. To clean, I use a medium firmness bristle brush and a spraybottle of 99% IPA, all in a tupperware container. A plastic scraper tool is also good for the more baked on old flux. I stole the cleaning method from Prime Hifi, shown in his YouTube video starting at around the 1h10min mark:
Stay tuned for more!
